start up icon - new template
lambertb
lambertb
I have a profile where I need to keep its name the same based on settings it loads but want to change between two template locations. Does anyone know if you can use the startup icon to set the new template without changing the profile?
C3D 2020
C3D 2022 and 2024
Joe-Bouza
The startup icon points to a profile to use.
Create the profile in civil3d that uses the files/ paths  you want and make a separate icon with the profile name pointer
Joe Bouza
AllenJessup
Yes, You can have as many startup icons as you want. Pointing to as many profiles and templates as you want. Just copy your original icon and edit as shown in this link.
https://blogs.autodesk.com/autocad/basic-autocad-customization-desktop-shortcut/
Allen Jessup
CAD Manager - Designer
zoeyanne
If I understand you correctly, you want to force an update to the profile without having to actually re-import the profile manually.  If you are loading a profile called "CompanyProfile" from a network location using a profile switch, it will be pretty easily.  Go to Civil 3D and rename your profile to anything besides "CompanyProfile".  I'd suggest adding the date to the original name.  Make your edits to this newly renamed profile from within Civil 3D.  Then Export your profile and use the original name "CompanyProfile" as the name of the profile you export.  When the software is launched, it checks the data inside the ARG file to see if it has a profile called that.  Remember that now your profile has the added date within the file.  Open the arg file with a text editor to confirm that the "CompanyProfile.arg" has the name "CompanyProfile-date" inside the arg file if you like.  When C3D is launched, it looks for the name found within the arg file.  It still has one called "CompanyProfile", but it won't have the one called "CompanyProfile-date" and it treats it as if it is a completely new profile and needs to be imported.  The next time the user launches CAD, as long as the same name is inside the arg file, it will recognize the profile name and use that until you have another update and need to change the date again.
Hope that helps!
Zoeyanne
C3D 2019
