SSA output file location
bforr
bforr
Maybe I don't understand, but in Storm & Sanitary Analysis Custom Report Options, I set an output file directory and still the pdf goes to my c drive\documents and and xlxs file goes to a file in my appdata location.  How come the Generated Output File is not saved to the location I set?
matt_anderson_pe
Wondering out loud if the PDF driver that SSA uses simply gets confused with the newer operating systems.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
