Hi there!
Someone knows why am I getting this error?
ERROR 115 : Adverse (or negative) slope defined for Conduit Tubo - (85)
I thought it was for the link routing method, so I change it to Hydrodynamic, but, when I do that, I get other error:
ERROR 600 : On grade Inlet Estrutura - (68) does not have two outlet links. At least one stormwater sewer pipe and a bypass gutter link must be defined.
ERROR 600 : On grade Inlet Estrutura - (69) does not have two outlet links. At least one stormwater sewer pipe and a
I think that, in my case, it should be really the Kinematic Wave method, because there's no structures with two or more outlet links, right?
I don't know what's happen.
My SSA file is attached.
Solved by Wojtek_Garczewski. Go to Solution.
Hi @nunesfns
Following errors are explained in SSA User's Guide (See HERE). Please see:
ERROR 115: Adverse (or negative) slope defined for Conduit nnn.
ERROR 600: On grade Inlet nnn does not have two outlet links. At least one
It seems that the in first positive slopes are not maintained, for a second that the at least one stormwater sewer pipe and a bypass gutter link is not defined.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
