SSA 2022 import landxml - parcel arcs are straight lines
C3D 2022
SSA 2022
Create parcels in C3D (thankfully only the polylines I chose created parcels; no small suprise parcels) and exported landxml.
Imported landxml file into SSA and all curves or arcs are straight lines.
I opened a new SSA file, imported xml, same result.
I opened a new dwg, imported xml, arcs are arcs, looks like it should.
The areas in SSA of the basins are correct, just the appearance is whack. When I print the map to turn in with my report, it will probably be questioned and it doesn't look right.
Quick check told me the only basin editing i can do is the add or move vertices.
Is there something new I am missing?
Can I change the lines to arcs?
Link copied
