Spot Elevations are not showing up correct
When I try to get a spot elevation (ex: 110.25) is is showing up as .25.  How do I get it to show up the number 110.25 example.
n_bartholomew
If you posted the drawing you are having trouble with, then it would be easier to help you with your issue.
It might be a number of things causing the problem, such as an individual label style component. an ambient drawing setting, or a surface that has been accidentally translated.
tony1978
Good evening. If you go into your Label Style Composer/ Layout tab and click your Contents options, this will bring up the Text Component Editor. In the Properties tab check to make sure that your output is set to full and not Right of decimal.  Let me know this works. 2021-07-29_1-04-10.png
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
tony1978
did this work for you?
 Tony Carcamo
President/Owner
Yes, it worked  thank you
