I have Civil3d 2016 SP1 (clean installed) on Windows 10 Pro 64. I am getting Error 1603 when I try to install SP2(64). I have gone through Autocad's basic steps with no luck so far.
Any ideas for next steps?
Thanks in advance
Solved by brburklund. Go to Solution.
Thanks for input. That is the steps that I followed with no success. I found via solution from trial and error.
When I would run the "C3D2016_x64_SP2.0.exe" file as an administrator, it would immediately give me the Error 1603. (BTW, I downloaded the file new today to ensure I had the latest version).
When I right clicked the file, I saw "Troubleshoot compatibility" as an option. I then tried running it using recommended compatibility settings.
That fixed it and it worked.
Hopefully, this may help someone else out in the future.
