Sortable Connected Pipe Invert Elevation to Structure Labels
jmckayimeg
jmckayimeg
Currently, Civil 3D provides the property Connected Pipe Invert Elevation for Structure Label Styles.
This property outputs multiple values but is implemented as a scalar, which prevents:
  • Sorting by invert elevation
  • Controlling order (ascending / descending)
  • Applying delimiters consistently
This makes it impossible to label connected pipe inverts highest to lowest.
Connected Pipes – Invert Elevations (Collection)
This property should support:
  • Pipe Selection (All / Incoming / Outgoing)
  • Sort By (Invert Elevation)
  • Order (Ascending / Descending)
  • Delimiter (newline, comma, etc.)
Is anyone aware of a work around besides splitting label by pipe direction and creating two text components:
  • Incoming pipe invert(s)
  • Outgoing pipe invert
OR by exploding label??
Thank you in advance.
RobertEVs
The SincPac has that option to Sort Connected Pipes which adjust labels to sort as well. Yes, it costs and is an add-on but will do what you are wanting. Loaded with TONS of other features.
Free 28 day trial.
sirjoelsph
Pipes in structure labels are sorted by the order the pipes were created in the drawing.  It's not ideal, but you can control the order they're listed in the label by creating the pipes in that specific order.
For some reason, I thought I remembered it being the order the pipes were attached to the structure, but I just tested in C3D 2024, and that wasn't working like I remembered.
-JOEL
obulesub
Hello, @jmckayimeg,
Did the information provided by @RobertEVs @sirjoelsph help you and answer your question? If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information. If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
Obulesu | Community Manager
