Oki. this is strange. suddenly the snap to corridor modell is not working anymore, not an xref. My colige was working in the same file and he was able to snap to the modell.
I checked my snap settings, tried to compare to other computers, but no luck 😕
Anyone have a secret magik setting to fix this?
Cheers!
Hi @Waterfree
Are you able to snap to other objects, e.g. surface, 3D Polyline?
Have you tried to rebuild the corridor? Did it give you any errors or warnings after in Panorama-Events tab?
Can you turn on all snaps(type OSNAP or press F3) and try if it works?
Can you share a screenshot from your OSNAP settings?
Eventually, can you share your problematic file with use?
Wojtek
I treid all that. installed 2021, compared the settings, still nothing.
Tried repair, reinstall and still no snap to corridor models.
Snap works fine on all other objects.
I had the same problem and found something that worked for me.
Change OSNAPMODE to 0. Then reenable with F3 and select the snap modes you want (endpoint, midpoint etc.).
After this it worked again for me.
Edit: I found that using some combinations make it stop working again. Try using only endpoint snap mode on (OSMODE 1).
