Snapping a Line to a C3D point and prevent getting the Point's Elevation
When I snap a line to a Civil 3D point, I don't want the line to take the elevation of the point.
I keep having to go into the properties of the line to change the Z value to "0."
I've used the OSNAPZ command but seems like OSNAPZ only prevents polylines (as well as a few other entities) from inheriting elevations.
I was wondering if there is a way to prevent the line from inheriting the elevation of a C3D point (or anything with an elevation).
Replies (11)
Jeff_M
OSNAPZ works all the time when drawing objects, or moving/copying/etc. with a command. It does not work when Grip editing.
For points, you could use a Point Style that flattens the display of the points to 0. You could also use the Transparent PointFilters, these can be found on the Osnap context menu
krzysztof.psujek
Hi, OSNAPZ = 1 should work also with lines,
I've just tested on my 2015 and works well.
Chris
Hmm okay.
I'm using C3D 2013, I set OSNAPZ to 1, but I still get elevations when I snap my line to a point
How do you change the point style to flatten the diplay of the points to 0?
I gotta look up more on that transparent point filters. Does the transparent point filter also include holding ctrl +right clicking and choosing the point filter?
Pointdump
Bman,
Here:
undefined
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Wow I didn't see that option!
Thanks again!
another option is to use the .xy filter and when it asks you for the z value you hit 0
rl_jackson
NOTE: If you flatten the points to elevation and you are using Survey Figures from a Survey Database, you will lose the ability to Grip Edit you figures.
This is exactly why I created my own command button to set OSNAPZ = 1 and run the points and figures at elevation.
Rick Jackson
Survey CAD Technician VI
I used to use that .xy filter option before also, but I think having to do that extra step takes up time.
Better to just snap to the points and have the line with an elevation of 0.
KirkNoonan
I think your thinking about the same setting in the survey figure style. Changing the elevation of the point style has no effect on the figures.
AllenJessup
I usually insert the points at 0 or use the OSNAPZ option (also have a button for that). But if you draw a polyline instead of a line and start the first vertex using the .XY filter. The 2d polyline will stay at 0 without any additional input.
Allen Jessup
CAD Manager - Designer
Type a product name
