Smoothing the intersect of grading
Crass
Crass
I am new to use grading. I am grading out two ponds at different elevations and in close proximity. Where the gradings intersect there is some weird stuff happening. From a strategy standpoint hat is the best way to smooth/control this area? My instinct is to start editing the surface to clean i up but I assume I would lose the dynamic nature of the grading criteria. Thoughts?
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
rl_jackson
Sometimes you'll need to add a featureline as a breakline to the surface to smooth things out.
Rick Jackson
Survey CAD Technician VI
TrainingNode-01
Hello @Crass
When 2 grading objects are on one site they will interfere with each other where they overlap.
What you need to do is
  • Place them (their feature lines and grading) on a separate site.
  • Grade the first pond to the EG surface
  • Create a combined surface of the first pond surface and the EG surface
  • Grade the second pond to the Combined surface.
For example:
Pond A is on Site A and graded to EG
Pond B is on Site B and is graded to a Combined surface that consists of Surface EG and Surface Pond A
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
Crass
Genius! This worked great. Thank you
AutoCAD 2018/2021
Joe-Bouza
@TrainingNode-01 This is a great approach. Kudos. how would would you approach getting say a 10-foot flat area between the two intersecting grading
Im thinking a 3rd grading pasting .. I hate adding partial grading with different criteria - that seems to always gum up civil3d
Joe Bouza
Joe-Bouza
YUP. Easy.
Joe Bouza
