Slope pattern missing on grading
Christie.G
Christie.G
I have two grading slopes, I used the same slope pattern and only one shows the slope pattern and the other one nothing. Can someone please explain why I can not get the slope pattern to show up. I have attached the PDF and DWG file to see if someone can tell me why this is happening.
ecfernandez
Hi @Christie.G, are you using a data-referenced existing surface? If so, re-synchronize your surface, and it might solve the issue.
I hope this helps, best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
Christie.G
Unfortunately that did not work.
Neilw_05
I was able to get the patterns to appear when I deleted and recreated the gradings.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Christie.G
I will try that but I did that numerous times and it didn't work.
ecfernandez
Hi guys!
I tried to reconstruct the grading, but I couldn't. I could see that the grading that is not showing the slope patterns is a grade to surface grading and the targeted surface depends on another surface that was pasted into them. I guess that the surface that was pasted somehow lost the connection with its original data from which it is being generated, and this is causing the issue. I have experienced this issue many times, and even though I have other gradings that look OK while targeting the same surface, it is just a matter of editing them to see the same problems.
I would encourage you to check the data references deeply, make sure they are OK, and try again.
Camilo Fernández
LinkedIn
Neilw_05
When you re-create the grading, try applying it to a smaller segment vs. the entire length. It works for me.
WIN 10 64 PRO
