Slope Labels on Corridor code set syle
john_vincent_pilarca
Hi everyone!
Anyone knows on how to create a code set label styles on the image below?
teerawat.pSCHYQ
first you need to set Link Code for this link, it might be not same other link, for example, maybe "SlopeLinkLabel"  after that go to the code set style editor, then import this code to your code style, and then create label style for this code.
after that you might be add some symbol block , this block might be have triangle and number 1. like this
and then you and add text contents for run only in the Text Component Editor  like this.
let see this section view with code set label for this link on the right hand side.
Thank you very much!
