Slope Analysis only give 2 ranges
neilyj666
Mentor Mentor
neilyj666
Can anyone shed any light on why I can only get 2 Slope ranges in my analysis - even when 6 are chosen?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Hidden_Brain
check the surface style, under analysis tab>slopes>group by. yours might be set to equal interval, change to quantile and run analysis again.
neilyj666
Perfect solution - that was indeed the problem....:)
doug_manville35K9Y
getting this same issue in 2020, 2022, 2023 and 2024. it is repeatable. something is broken. i can see the analyzing date box flash then then it stops. any one else having this issue.
Udo_Huebner
If the terrain consists of only a few and very flat triangles, it may not be possible to create as many ranges as entered. In this case, first check the surface statistics or post the DWG here.
Gruß Udo Hübner (CAD-Huebner)
doug_manville35K9Y
doug_manville35K9Y
Thanks for the fast response.
I am able to create a new style and to get it to work, but I can't see any difference in the 2 surface styles. I tested your theory on the limited triangles on a test surface and was able to produce the error as you have stated. this surface has a lot of triangles. I'm wondering if the surface style is corrupt.
