Hi
Could you guide to the Sub Assembly which I could use for Slab with offset target for variable width and Elevation Target for variable thickness (top surface fixed). If there is no such sub assembly, could you work out and send a PKT file for me. (See Attached image for my requirement). Thank you in advance. I use Civil 3D 2018.
Hi
Solved by shashimanandhar1417. Go to Solution.
Don't Worry, I managed to create the sub assembly to my requirement. (See attached PKT file in zipped form)
