I was wondering why I can not open single line text from either the menu bar or the tool sets palette. If I go to the command bar no problem. All the solutions I saw use the command line.
Greg
Solved by AllenJessup. Go to Solution.
Do you mean you cannot execute the command from the menu or tool palettes?
Post a screen shot of where you're going to invoke the command. Are you saying you press a button and nothing happens or are you saying there is no button?
Hi @Anonymous.
Does this problem persist after closing then reopening the program? Are any CUI (menu) files on a network path that might not be available?
If none of these are it. You might want to repair the installation.
Allen Jessup
CAD Manager - Designer
