Shortcut Repair - Incompatible Results
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I had some issues with a Shortcut. I deleted it from the folder under _Shortcuts and recreated it. That worked. However, now when I try to repair Shortcuts, I get a couple of messages about Incompatible Results Found. It says the Name was found but the Name is not an option in the "Use to Match" field.
Using the Data Shortcut Editor. I see that the Use to Match field is set to "Handle or Name".
So why would I be getting these messages?
Allen Jessup
CAD Manager - Designer
