Sheet Set Manager Error: Cannot find the specified file.
C3D 2016 Win7
When I try to generate a sheet set using SSM, it bombs with an error: Cannot find the specified file. Please verify that the file exists. It sometimes stops at the first sheet, it sometimes gets through all of the sheets before it stops. The sheet drawings are produced accordingly - either one sheet or all.
There are xrefs - in the parent drawing and the title block in the sheet template. They all seem to be found and attached correctly.
Is there another file that sheet generation needs? This worked fine two days ago, then beginning yesterday I started getting this error with sheet production aborted.
tcorey
Are you keeping a plot log file? That should more fully explain the error and identify the missing file.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
1. right click and save all sheets; go get a snack while that goes
2. someone may have renamed the tab; check the properties of each in ssm
Joe Bouza
