Thanks for the informatioon, @Jacob.IsomHASK
SSM Is powerful, but has its limitations. As is often the case with AutoCAD/Civil 3D, Work Arounds can help.
You can add "dummy sheets" to the SSM to represent these "foreign" drawings.
See the following video: Adding PDF files to your Sheet Set in AutoCAD | AutoCAD | Autodesk Knowledge Network
The video goes into detail about adding the PDF to the dummy DWG file and actually printing it from SSM. You do not need to go that far. Once you have the dummy files in the SSM, you can manage page numbering and sheet titles using SSM rather than an external file.
As I see it:
- Using SSM requires creation of dummy files for foreign sheets, but after that, all sheets are managed in SSM. A SSM based sheet list is easily updated.
- Using an external file makes all sheets "foreign", including the sheets that you create in AutoCAD or Civil 3d.
- You will need to manually update foreign Sheet Title and Sheet Number in your external file.
- You will need to manually update or link Autocad/Civil Sheet Title and Sheet Numbers in your sheet files and your external file.
(There is a risk of things getting out of sync. SSM eliminates both update and sync. issues)
- You are free to pick the approach that works best for you.
Possible advantages of SSM:
- Ease of publishing. If you add Xref attachable (PDF, DWF, DGN, image) versions of the foreign sheets you can include them in the dummy file as shown in the video.
(I would include the image full size with out my company border.) - If you include the foreign sheet image in the dummy sheets you can add SSM fields if necessary. Say a foreign sheet is "Structure Site plan", "Sheet S-1 of 4"
You could add a marginal note like "My Company, Project 1234, Page 15 of 23 Total", where SSM based fields are indicated as 1234.
1234 would be a SSM Property.
"Structure Site plan" would be a manually populated SSM Sheet Property.
"S-1" would be a manually populated SSM Sheet Property.
15 would be a SSM Sheet Custom Property.
23 would be a SSM Custom Property.
Good luck. Keep us posted if you decide to look at eh SSM approach.
Christopher Stevens
