I have some custom subassemblies that I created with subassembly composer and it works well with my computer.
When I send it to my coworker and he tries to use it it says "one or more subassembly macro (or.Net classes) could not found" The only way for it to work is for him to open it with subassembly composer and save it on his computer and then import it to his tool palette.
And when he opens a drawing that I put the subassemblies into he needs to replace them with the ones on his computer in order for it to work.
If he does not replace it then it either does not show the custom parts of the corridor or he can't edit targets.
see the attached example of the custom assemblies.
Thanks in advance
Solved by ytzvib. Go to Solution.
Solved by Jowennl. Go to Solution.
Rename it to .zip and we can rename it back to .pkt.
Hi @ytzvib ,
I assume you both uses the same C3D Versions and same windows version. Can you please check if both of you got the same .NET framework version and atleast 4.5 and above. For example C3D 2018 you can use .Net framework 4.7
Get the <.NET Framework Link>
For sharing PKT, I prefer to share DLL and make it synchronized with the team. For more information about sharing custom subassembly. You can try the link below,
<AU Class Video Link> watch 42:24 - 50:25
<AU Class Handout Link> Refer to pages 25-28
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
What I ended up doing was after importing the subassembly into the tool palette I copied the entire folder that was in C:\ProgramData\Autodesk\C3D 20xx\enu\Imported Tools\<subassemblyname> and copied it into the same location on my cow workers computer and it works fine now.
I used the below link to find the location.
