Shared Reference Point for C3D 2024
pilarcajv
pilarcajv
Any ideas on where to download shared reference point for civil 3d 2024? Currently it is not showing on my manage account and desktop app.
huamani1277
Hola, si te refieres como exportar el archivo de punto de referencia para Revit. lo primero que deber realizar es instalar la aplicación shared reference points, luego ejecutar muestro un imagen del caso
JHM.
lim.wendy
Hi John,
Thanks for reaching out to the forum. The Shared Reference Point extension is built into Civil 3D 2022 & newer. Prior releases will require you to download the add-on separately.
The Shared Reference Point extension can be accessed through the Autodesk Desktop App or through Autodesk Accounts page.
Additionally, you will need to download the extension separately for use in all versions of Revit.
In Civil 3D, go to Toolspace limwendy_0-1693983967739.png Toolbox limwendy_1-1693983967742.png Subscription Extension Manager limwendy_2-1693983967743.png Autodesk Shared Reference Point limwendy_3-1693983967743.png
 Export Shared Reference Points for Autodesk Revit.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
pilarcajv
Thank you! Thought it was still on the subscription extension. Cheers!
