C3D 2020
used task pane to bring in labels for soil type shapefiles from web soil survey. Some labels are off a bit, some have overlapping labels. So I clean it up by moving the labels (properties say they are text objects) and deleting overlapping. Looks great. Save or switch layouts and deleted labels and placements reappear. I don't see where you can fix this. Can't explode, copy, or bind like an xref.
Anyone know how to overcome this?
Solved by ToddRogers-WPM. Go to Solution.
Solved by Pointdump. Go to Solution.
Bryan,
Recommend using a >>>Map Annotation Template<<< for labeling.
Dave
Dave Stoll
Las Vegas, Nevada
You can also select the Maps icon in the task pane and choose Save as AutoCAD drawing. This will turn everything into AutoCAD entities.
Thank you both for your quick response and solutions. Each has it's benefits. For the mapanntext, it was easy to do and kept the changes. I still had to move some around probably because of the shape of the "parcel". When I updated annotation I had the choice of retain or ignore (something like that) and I chose retain. The labels moved back to original insertion but the items I deleted were um deleted. ha. I undid to the point and chose ignore and they all went away. I tried REA but they didn't appear, so I retained, moved and saved. All good. For the pick Maps icon, it did save them as a group which I could explode and delete/move which was good, but it changed all the mtext in the dwg to ####. If the shapefiles were the only objects in the dwg, it'd be fine.
Got the results I needed. It's a great C3D day!
