Setting viewport USC to View in a layout
sharon_dana
sharon_dana
I work plans production, so a lot of time I am working in a layout with a viewport.  I am used to setting my Viewport UCS to View, beaning doing it the same way for 20 years in AutoCAD.  But, it recently I have a continuing problem of when I leave that viewport to go to the paper space or to a different viewport, when I go back, the UCS has changed back to World.  Hard to line notes up to the paperspace rotation when the UCS in the model space won't stay at View.
What I do: in the layout:  use "Alignspace" command to rotate the model space to the orientation I want.
set the scale to what I need,
type in USC >> View  (check that UCS rotated correctly);
Lock the viewport.
Is there a setting in Civl3D that I am missing to have it hold the UCS View in the viewports?  My co-workers say they don't have the problem that I am experiencing.
brian.strandberg
I don't see any reference to using the PLAN command to rotate the view to make the view planer to the new UCS.  Its possible in the past you had UCSFOLLOW=1 which does this automatically.  Its typically 0 by default.
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
sharon_dana
Thank you for the reply.
We keep the UCSFOLLOW set to 0, otherwise it zooms extents every time we change from paperspace to modelspace.  With a 12 mile long alignment, it is nice to return to the spot I was last working on when I "switch space".
I am not familiar with the PLAN command.  When I used it in my viewport, it caused the view to zoom out to extents and I had to reset the scale but it seemed to have the right orientation.  Now that I got it sized right, hopefully it will hold the UCS as set to View.
