Hi
Since I am new to Civil 3D Site design and corridor modelling, i am facing a problem with one of the corridors. The problem in a nutshell is that i have a corridor with a service road, I made an assembly to model the corridor with the service road, However there is a break at the transition/ entrance of the service road as seen in the screenshot below, Moreover i dont know why the median is not showing at this location also, please help if you know how i can solve this. I have attached two images one showing the entrance and the service road and the assembly used.
Dear Friend,
Please check this video whether the inputs suit to solve your issue.
https://www.youtube.com/watch?v=5VY_s-J08d0&t=64s
its difficult to see what you are trying to achieve but it looks like a transition from one assembly to another?
If that is the case, Civil 3d doesn't do transitions well, you either need to use a featureline (or vertical profile) to target your elevations for your targets
OR
split your corridor and leave a gap in it (say a 10m transition zone) and allow the surface to fill in the gap and act as a transition
Yes exactly my question was about having a proper transition between two different assemblies. Moreover if you've noticed i am using an assembly which is having two medians using the mark point approach to do so, however it is showing as a gap so the question will be
Can i make an assembly with two medians meaning that it will have two mark points ?
Finally is it a common practice to leave a gap in the corridor and just let the surface fill this gap ? what if i wanted to see a section there ?
Please accept my apology for these too many questions 😄
Unfortunately, the problem is with the corridor itself not the surface however this video helped me to fix some other areas.
Thank you very much
The only way you could do this is targetting the edge of the assemblies over the transition zone with either a featureline or vertical profile
The leaving a gap in the corridor is an accepted solution by most users who do it
And there is never too many questions, this is how we all learn, helping people come to solutions for their problems help us overcome the same problems in the future (or if we already have a solution then for how we have overcame it in the past).
