Selecting Multiple Pipe Network
aidilfitriansyahhV7KXB
Hi All,
I'm dealing with hundreds of pipes and manholes, and need to split them into different networks. Is there any way to select the network from a manhole to another but also select the pipes in between?
For example, from the yellow circles, the rest of the pipes and manholes in between also selected.
Joe-Bouza
You can select fro plan or prospector. Once selected the ribbon adjust, pick split network. The command line option is create new or select a network to add the selection to
Joe Bouza
Nilesh_Chaudhari
@aidilfitriansyahhV7KXB  let me the above solution works for you.
If you need more help then please reply
Nilesh Chaudhari
Product Support Specialist
Yes Nilesh, would be appreciate if you can show the solution may be in the video
Joe-Bouza
Post your pipe networks for demonstration video
Joe Bouza
