So, when you right click on a selected entity “Select Similar” used to be at the bottom of the shortcut/context menu. In 2024 they have added “Count Selection” under it. This is no fun for a person like me with old habits. I saw where you can customize in the CUI, but I did not see the “Count Selection” item anywhere. Is there a way to edit so I can have “Select Similar” at the bottom?
Solved by RobertEVs. Go to Solution.
That has been an ongoing topic of discussion with no results. Do you happen to have an extra mouse button you can assign?
Bummer. Thanks for the link. I did a little searching but I was thinking it was a 2024 thing. We just went from 2021 to 2024. Its not the end of the world. I have some custom toolbars, but my hands have been doing the same thing since the 90's. It should only take a bit to get used to it.
