Select cogo points or create cogo points group with specific distance from a surface
nkiakas
Advisor Advisor
Message 1 of 11
nkiakas
Hello to the community
Does anyone knows how to select gogo points (or create a point group), for example, the points are above (higher) than a surface...
I tried the "quick select" command but did not find anything suitable.
Thank you
Replies (10)
Message 2 of 11
Pointdump
Hi Nikolaos,
Project Exporer can do this by selecting "compare to".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 11
TerryDotson
Does anyone know how to select cogo points ... above (higher) than a surface.
For anyone who does not have access to the Project Explorer (because of not having the Autodesk AEC collection), this functionality is included in DotSoft's C3DTools.
Message 4 of 11
Pointdump
Hi Terry,
I keep hearing that Project Explorer and Grading Optimization can only be installed in the AEC Collection, but I've got both PE and GO in my Civil 3D 2023. Unless I'm mistaken, I don't have, and have never had, the AEC Collection.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
AllenJessup
@Pointdump
What does you account page say?
Allen Jessup
CAD Manager - Designer
Message 6 of 11
Pointdump
Hi Allen,
I guess it's available to me, but I've never installed it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 11
Pointdump
I've only ever installed "Standalone" Civil 3D. Right now I have 2022 and 2023.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 11
AllenJessup
If you made Surface from the points in question and then created a Volume Surface comparing the surfaces. Then make a cut/fill map. Any points that fall in the cut areas will be above the original surface. You'd have to select them to add them to a Point Group.
Allen Jessup
Message 9 of 11
chriscowgill7373
@Pointdump wrote:
Hi Allen,
Dave
Getting a little off topic, but to provide a little clarity. If you have access to a license of AEC, you can install PE and GO and they will run, you dont have to install from the AEC to do that.
If you have a standalone subscription of Civil 3D only, you can install PE and GO, but they will give you licensing errors when you try to run them.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 10 of 11
rl_jackson
Possible EE bennies
Rick Jackson
Survey CAD Technician VI
Message 11 of 11
Neilw_05
Allen Jessup has the right idea but it can be simplified.
Create a volume surface to establish cut/fill conditions. Use the Elevation from Surface tool to set the COGO point elevations to the volume surface. Any points with elevation <0 are in cut relative to the base surface and vice versa.
You can filter the points even further based on the relative distance above or below a surface. Create point groups with criteria for elevation ranges (ie. z>0 & <=1, z >1 & <=2, etc).
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
