Segmenting point cloud from within 3D object
Hey all,
I've imported LiDAR data (point cloud) into Civil 3D and I wish to segment all points which fall inside a 3D object (cylinder/prism) from the point cloud, then export these points as a new point cloud file.
What is the best method/workflow to do this?
BushW
Hi @Anonymous
I see that you are visiting as a new member to the AutoCAD Civil 3D forum. Welcome to the Autodesk Community!
Please review these threads Point Cloud Workflow Point Clouds, and Point Groups,  and Query point cloud boundary then add all the points within the boundary to see if they offer a solution to your question and a possible workflow.
This information will help you with importing point clouds into Civil 3D, apply a border and use a point filter to place points into groups allowing you to export points to a new point cloud file. Hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit.
Wendell Bush
Civil Infrastructure Technical Support Specialist
BushW
Hello @Anonymous
I'm following up to see if you had the opportunity to review the information I posted in my reply.
Are you in need of more help with segmenting point cloud from within Civil 3D?
If my last reply answered your questions, please hit the ‘Accept as Solution’ button if my post solves your issue or answers your question so, that others can more easily benefit from the information. This lets me know that I was useful in helping you, and thank you for doing so.
Wendell Bush
BushW
Hi @Anonymous
I just wanted to inform you that I’ve just accepted your reply to your post as a solution with the understanding that this a solution to your issue.
If my answer did not work as a solution, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
However, I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns I am here to help!
Wendell Bush
