- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to use text component editor to add a space between the N/E/W/S directions and the degrees minutes/seconds. Is that possible to automate when using segment labels?
See snippet for what I mean, above the line is what the segment label generates & below the line (mtext) is what I want the label to generate.
I'm also attaching the text component editor setup if that helps.
