Section views showing wrong assembly
mabelourgos
mabelourgos
Hi, I am using a rail assembly for my corridor but the section views I produce are showing another assembly.
I have tried many solutions from building the corridor again with different name after deleting everything from the prospector and the sample lines sources...to auditing and recovering the dwg...I am using civil 3D 2020 and I have many issues with section views. Furthermore sometimes my section views stopped showing anything from my corridor (the corridor exists but has zero left and right offsets).
As you can see in the attachments I am using the left assembly but the sections views showing a mix of the two assemblies.
Hi
did you add corridor surface ?
what did you mean by wrong assembly , what is the wrong?
mabelourgos
No I don't have any surface in my corridor.
As you can see in the assemblies.png there are two separate assemblies.
I am using the left one for my multiple sections views group. But when I produce them, there is a subassembly displayed in the upper right (generic pavement structure) which is not a part of my assembly. Furthermore from one point and then, whatever I change in corridor (code sets, targets etc) or in the assembly adding or removing a subassembly is not always depicted in the section views.
mabelourgos
I think that these images describe the problem better...In section view there are initial corridors which are no longer exist in the drawing... I have tried audit recover and deleting the sections from the toolspace. I am searching for a solution other than building the corridor again with new sample line group.
Section View & Section View Group Properties.
