Section views not showing
My setion views do not display nothing, my intent is to display my corridor. Would anybody know what the possible problem is and could also explain the solution clearly?
Jeew-m
Hi civil-student,
Make sure you have sampled corridor in to your sample lines.
If not you can select a sample line and go to add more sources and add the corridior.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Ok i got it, it believe it was also because i had my pipe networks selected as sources on sample line aswell. Is it possible you could check out my most recent question? Thank you.
