Section Views Not Displaying Level Difference
e_honey
e_honey
Hi all,
I'm trying to generate section views for a very simple design, however I'm continually running into the issue where the sections are plotting, and displaying the Proposed Levels ("Design" tin) with the same values/heights as the Existing Levels ("Survey" tin).
This means that the Level Difference is 0.
I'm not the most experienced Civil3D user, but I've tried for quite a few hours and done some extensive googling, and have been unable to find an answer. I assume it has something to do with the styles?
I'm using the ANZ Civil 3D Country toolkit, for reference.
ianjchap
Hi @e_honey,
You need to swap out the sample source in the band style. Click on your section view, goto section view properties. From there goto the Bands tab, under the Section 1 & Section 2 you can change the source Surface that the labels read from.
For the Level Difference band, you'll need to have the Proposed Surface as Section 1 and the Existing Surface as Section 2. (or VV)
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
nkiakas
Hi @e_honey
Can you share your file to take a look?
Regards
