Section Views - Create Multiple Views
demus72
demus72
I have an alignment and sample line group with 16 sample lines. When I Create Multiple Views, it creates 3 columns of 3 with the last 8 section views staked on top of one another.
We are using a production template. Could this issue be caused by the template or could there be a style issue in the current drawing?
ecfernandez
Hi @demus72, can you upload your file to check it?
There might be many reasons why this is happening. Therefore, it is best to check directly in your file.
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
ChicagoLooper
Hi @demus72
It looks like your 'production template' is trying to fit the views a in viewport but the views don't have enough room.
Have you tried using a different template that can accommodate a larger sheet size?
Or select all those overlapping views to get the Contextual ribbon. Then go to Modify Sheet Panel=>Update Group Layout.  You may need to adjust your drawing scale before you update, e.g. like image below.
Chicagolooper
