Section View: Projected Objects
shashimanandhar1417
shashimanandhar1417
I have a situation where in my section view, when I tried to add 3d Pile blocks as projected objects they appear as plan view (not the section or elevation view). Any thoughts or solutions for this problem (Snap Shot attached). I use Civil 3D 2018.
Wojtek_Garczewski
Hi @shashimanandhar1417
Thank you for posting. Does it look the same on the other sections, or the problem is present only on the one specific section?
Could you share your file with us, so we can take a look and troubleshoot your issue more efficiently? Thank you.
Wojtek
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
shashimanandhar1417
Hi Wojtek G,
See attached file. Your help would be much appreciated.
Topmig
@shashimanandhar1417 ,
Just exploded the blocks and it worked.
With just the 3D solid it's possible to see the entire object.
See attached
Hope it help's.
shashimanandhar1417
Hi Topmig,
Thank you for finding the solution to my problem. Did not realise Blocks do not work for projecting on Section views.
King Regards
Shashi
