Section view production, adjust auto elevation to reduce empty space in section views?
m_kingdon
Advisor Advisor
m_kingdon
Hi all,
I don't often work with cross sections so I am having to build the company template.  The automatic elevation datum seem a little conservative and is leaving a decent amount of sheet space under each cross section.  It is possible to have any control on how Civil 3D automatically assigns a datum to a cross section?  I don't want to manually assign an elevation to each cross section, there are too many sections and the elevation varies too much for this to be practical.
Mike Kingdon
Civil 3D Zealot
ecfernandez
Hi @m_kingdon, this AU Class might help you
Link: Stack Your Sections: Tips for Building Section Sheets Efficiently
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
MichaelH13
Hmmm, I know Hillcrest Road 😄
rsanlatte
Community Visitor
Community Visitor
We are having the same issues not being able to change the datum for all cross sections but to individual cross sections. We didn't find the report or the solution to the problem. Any way you can reply with the solution or fix?
? I Your help would be highly appreciated.
Kind Regards,
Ramon Sanlatte
