Section View no Assembly
I have attached drawing with surface (EG), Alignment (0 to 6 Km), Profile ( Design Profile), Assembly ( 0 to 2Km) & Corridor. I am not getting assembly in section view and getting only surface line, not able to detect problem
Jeew-m
Dear Friend,
You have not created sample lines properly. Delete all existing sample lines and section views. Then do it as in the video. Even though the topic of the video does not seem to comply with your topic it has some steps that helps you. Hope it will solve the issue.
https://www.youtube.com/watch?v=c1PumORHYFk
If needed you should use sample more sources as well.
http://blog.civil3dreminders.com/2009/12/sampling-more-sections.html
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
tmachado
Hi @Anonymous, you need to go under sample more sources, and get that info to show on yopur sample lines...
2017-08-09 15_16_42-Autodesk AutoCAD Civil 3D 2017 - [Forum.dwg].png2017-08-09 15_17_45-Autodesk AutoCAD Civil 3D 2017 - [Forum.dwg].png
Here is your file back with the sections on it.
I worked with C3D 2017
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
BushW
Hi @tmachado
I am glad to hear that it this solution worked.
Here to help!
Wendell Bush
Civil Infrastructure Technical Support Specialist
Hi.
Thanx for you co-operation, your illustrative answer help me in going forward in my project.
Regards
tmachado
You are welcome!
Tatiana Machado
