Solved by hoshki. Go to Solution.
I ended up calling tech. support. I had to recreate my sample groups and sections to get them to update. Apparently they dont update themselves. Thanks anyway! Edited by: dab829 on Jan 27, 2009 3:04 PM
I know it's a long time since the post but I had this problem and it came first in my google search.
Solution : Select a sample line, right click menu, select 'sample line group properties' got to 'sections' tab. in the right hand corner select 'sample more sources' and add your missing surface there.
Thank you. The issue still remians 10 years later (!) and luckily the fix also works.
If it only occurs in one section view in the sample line section view group, it is possible to switch "section wiew properties" for the specific "section view", under "Section" and then change "update mode" to static and back again to dynamic.
Regards Hallvard Skrede
