C3D 2023
Assembly (see Assembly.png) has a flat 1' width subassembly with a LinkSlopetoSurface on Left side and a 1' wide flat width with a LinkWidthAndSlope targeting a feature line on the right.
For some reason, in one region of the corridor run, the flat on the left side extends 7', the right 4.5'. And the center is off 3.5' to the left. (wide section snip.png) Attached also is normal section snip.png showing how the other 10 regions show in sections.
The corridor is made up of 11 regions from breaking up a 3,200' long run. All regions follow the same alignment horizontally and vertically.
I am hoping someone has seen this and can tell me why.
Solved by bforr. Go to Solution.
