search for words in drawing files in folder of many files
tt501613
Message 1 of 15
tt501613
I need a way to search for words within drawing files in a folder of many files.  Not words in the file name or words in a block attribute, (the design center search does this but this is useless) but general typed in words that could be in a note, title block, or say a detail within the drawing.
Thanks in advance,
TT
Replies (14)
Message 2 of 15
SMorykin
@tt501613  - This is an old forum post, maybe it will still help?
https://forums.autodesk.com/t5/autocad-forum/changing-text-in-multiple-drawings/td-p/3283973
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
Message 3 of 15
Joe-Bouza
JTBworld.com has a batch attribute editor that will scan as many files as you wish
Joe Bouza
Message 4 of 15
tt501613
I don't want an attribute editor, I want something, hopefully free, that will tell me what drawings contain a certain word or words out of a folder of autocad drawings.
TT
Message 5 of 15
TerryDotson
DotSoft has just released the drawing search tool from ToolPac in our freeware section.  Search quickly through multiple drawings for specified word strings, while specifying which objects and tables to search.
This has also been submitted to the Autodesk App Store, but it usually takes 2-3 weeks for review and approval.
Message 6 of 15
tt501613
Thanks Terry but I could not get the software to run.  Something about "loadFromRemoteSources switch" which I know nothing about.
TT
Message 7 of 15
Joe-Bouza
sorry for the misunderstanding
Joe Bouza
Message 8 of 15
TerryDotson
.NET Assemblies should be placed on a local drive (not a network volume) to avoid the need to use CASPOL.  Make a folder like C:\CADSTUFF and place the contents of the ZIP in that folder.  You may need to add a trust to that folder in AutoCAD, that procedure is documented in the tools help section.
Message 9 of 15
lynn_zhang
Hello @tt501613
Just checking to see if your problem has been solved. Let us know if you still need help!
Lynn Zhang
Message 10 of 15
tt501613
Lynn,
Still no luck.  I have loaded the .cuix program and I see the ribbon tab but when I click on it I get,
Command: DWGsearch
Unknown command "DWGSEARCH".
I have checked my security options and the folder is a trusted folder.
???  What now?
TT
Message 11 of 15
neilyj666
@TerryDotson this looks useful but it doesn't run for me - any ideas??
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 12 of 15
TerryDotson
With the ZIP package you also need to NETLOAD the appropriate DLL file (likely DwgSearch18a.dll).  I got word that the AppStore build is approved and should be available tomorrow, which will have an easy to use installer.  So if NETLOAD doesn't do it, delete the downloaded files and check this page tomorrow.
Message 13 of 15
neilyj666
@TerryDotson  downloaded from app store, installed and running with no issues....😀
Message 14 of 15
TerryDotson
... downloaded from app store, installed and running with no issues.
Glad to hear it.  If the tool makes you more productive, please consider leaving a brief review with a ranking (up to five stars) at the App Store.
Message 15 of 15
jae.kwon
Check out Lee Mac's Batch Find and Replace lisp available here: http://www.lee-mac.com/bfind.html
