Scale object in one direction with scale function
helloworld727
Message 1 of 8
helloworld727
Good afternoon,
Is it possible to use the scale command in only one axis?
Understand that you can create a new block, but it isn't appropriate for what I'm doing.
https://forums.autodesk.com/t5/autocad-forum/how-to-scale-in-one-axis/td-p/5299749
Kind Regards,
J
Replies (7)
Message 2 of 8
rl_jackson
Besides using a block, I can't think of one without knowing what your end goal is or what exactly your trying to achieve.
Can you indulge us with just a weeeee bit more information?
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
helloworld727
Hi Rick,
Am wanting to scale up different components of this excavator. Ie. the tracks to 4m width, but leave the length the same and so forth.  I know other programs allow this, but was hoping there'd be a function in C3D.
Cheers
Message 4 of 8
rl_jackson
So I would think you could use a dynamic block to achieve your goal. You could even set different increments that would be a simple grip function that you could set to certain nominal values.
HTH
Rick Jackson
Message 5 of 8
jroot
Message 6 of 8
Joe-Bouza
This is an AutoCAD function not a civil3d. I agree with @rl_jackson  the dynamic block feature of AutoCAD can give you independent scale and various lisp function in AutoCAD as @jroot  pointed out.
Joe Bouza
Message 7 of 8
Make a block, set the X,Y scales where you want, explode the block.
Message 8 of 8
iant123DM83S
I found this helpful:
Create a block.
Edit X & Y scale independantly in properties
https://www.youtube.com/watch?v=DEzpVPz7Kx8
