Scale Bar Scale Ratio does not match Viewport
mwilliamsK3SDE
mwilliamsK3SDE
When I go to Layout Tools > Scale Bar > Select Built-In > Click Viewport
The Scale Bar Ratio does not match the Viewport Exactly. This starts providing scales larger than 1"=50' with a 0.0001 at the end. I have tried everything to fix. Please help.
paullimapa
sounds like an AutoCAD Map question which may get better feedback here:
AutoCAD Map 3D Forum - Autodesk Community
Paul Li
IT Specialist
@The Office
cadffm
CIVIL3D!
Sebastian
TheCADnoob
Have you changed your units since adding the scale bar? If so try reading the scale bar.
CADnoob
Type a product name
