Save window not showing up
TTamburri
Message 1 of 48
TTamburri
So when ever I save something I get the file path and information coming up in the command bar but I am no longer getting the extra window showing up on the screen. I was wondering if anyone has come across this before and if you now how to fix it?
Replies (47)
Message 2 of 48
SethHall
Hi tbyrne-
Try FILEDIA and setting it to <1>. This should allow your save dialog to display again.
Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 3 of 48
TTamburri
Thanks so much.
Message 4 of 48
Yea, just had the same thing here on 2011, and also some day ago on 2010. Why does it happen anyway I didn't touch a thing 😛
Message 5 of 48
If you are using lisp routines, you might have one that sets filedia off and doesn't restore it if the routine fails for some reason.
Message 6 of 48
very very thanx
Message 7 of 48
It Worked. Great!!!
Message 8 of 48
Thank you!!!
Message 9 of 48
fguzma4
Community Visitor
Community Visitor
Thanks, it works. I am using autocad Electrical 2015. Thanks so much!
Message 10 of 48
My FILEDIA setting is already set to <1> and is still not showing the save window after pressing <OK> in plot window. What other possible solutions might there be? I am using AutoCAD Plant 3D 2017.
Message 11 of 48
thanks folks!
Message 12 of 48
thank you so much i fixed it
Message 13 of 48
Thank you
Message 14 of 48
Thank you so much ! i had the same problem and it worked.
Message 15 of 48
genius !!! well done
Message 16 of 48
Mine just did the same thing... Fix worked great!  Thanks!
Message 17 of 48
Yes it worked for me
Message 18 of 48
thanks a lotWoman Very Happy
Message 19 of 48
thanks a lotttttttttttttttttttttttt
Message 20 of 48
RAGHUVEER814ZDVTC
Observer
Observer
Thanks a lot
