Civil 3D Forum
Save template file but without Civil 3D stuff
6 REPLIES 6
neilyj666
262 Views, 6 Replies
I'm creating a template for use by AutoCAD LT users and I want to use my Civil 3D one as a basis but ensuring I've deleted all the Civil 3D styles etc etc.
I've run the Manage > Purge Styles and there are no unused styles but there is a Cut grading style and Fill grading style still showing in the Prospector tree as well as Plot Styles and I can't work out how to remove these. There are also a load of layers that I can't delete presumably because they are still associated with a Style somewhere
Anyone got any suggestions as to how I can clean out all the Civil 3D detritus?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Labels (1)
6 REPLIES 6
v-silvestre
in reply to: neilyj666
Hi @neilyj666.  What about starting with just the acad.dwt and importing everything from there?  Not sure how much info you've got, but I can imagine it's easier to import acad info rather than removing c3d info.
neilyj666
in reply to: v-silvestre
@v-silvestre I'm rapidly coming to this conclusion...😊
tcorey
Does _ExportToAutoCAD not work for you? This will strip the file clean of all vestiges of Civil 3D styles. Objects will be lines, arcs and polylines. Mtext instead of Labels.
If you open the file in Civil 3D, all styles will be Standard.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
v-silvestre
in reply to: tcorey
great call! I totally forgot about that option
neilyj666
in reply to: tcorey
I'll give that one a try too
neilyj666
in reply to: tcorey
@tcorey This method looks promising...🙂
Rail Community
