In the Toolbox for C3D 2015, there was a utility to save a survey database down to 2014 format.
In C3D 2016, it's gone.
Anyone know where it went?
Solved by rl_jackson. Go to Solution.
Don't believe there was one. But I would think you could use the one in 2015 to save it down, 2016 didn't make any SDB modifications. The only reason it happend in 15 was due to SQL changes.
Rick Jackson
Survey CAD Technician VI
I can because I still have 2015 on my pc, but we're migrating everyone to updated pc's with only 2016, so I was wondering where that utility went and why.
You should be able to go to the Toolbox and create the tool in 2016, then just set it to a path on your server. Then just do the same for each workstation. Do you really plan to backdraft the SDB often?
Rick Jackson
Don't need to save back often, but if you do that tool is nice to have.
I figured out how to recreate it in 2016. Thanks for the idea.
