SAC: Unable to get offset value from offset target.
JanArieVisser
JanArieVisser
My Subassembly (SAC 2022) will not target the second appointed offsetline on the left side. Its a straight copy from the right side. It will only offset to the first appointed offsetline.
I've included the DWG , PKT and a screenshot
ecfernandez
Hi @JanArieVisser, my advice is to divide your assembly into two subassemblies. One for the left side since I see it is different, and one for the right side. This way,  you can activate the side variable on each subassembly (I see you have Side=None). This will give both you and the software complete clarity about if what you are targeting is on the left side or the right when using the subassemblies in Civil 3D.
I hope this helps.
Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
JanArieVisser
Tried to get it to work with only the top lines in the assembly, even tried to get it to work with an alignement instead of a featureline. Didn't get it to work although it should work without specifically splitting it up in a left and right part.
In the end I made a totally new assembly with left and right part as described as above.
ecfernandez
Hi @JanArieVisser, good to know that could solve your issue. It is always better to break it down.
Best regards!
Camilo Fernández
LinkedIn
