running the audit command corrupts my feature lines
CFernets_IEAC
CFernets_IEAC
running the audit command deletes the feature line inserted elevations
Accepted solutions (3)
Replies (13)
troma
What version of C3D are you running?
Are your service packs up to date?
Mark Green
Working on Civil 3D in Canada
CFernets_IEAC
civil 3d 2016.
All service packs are up to date.
CFernets_IEAC
i found the hotfix link and followed the instructions... works prefect. tks
CFernets_IEAC
found the hotfix link.. followed the instructions... all good. cheers!
Hi, I am having the same problem, do you know which Hotfix addresses this?
vinceroux
Hot fix 3 is supposed to fix the original feature line issue.
A bug still exists despite this hotfix. I've already gone through the support team and was told the dev team is looking into it.
Auditing (with error correction) non-closed feature lines with grading objects will explode those feature lines and grading objects. This does not occur with closed feature lines.
troma
What version are you running?
Are feature lines without a grading affected in any way?
Mark Green
Jay_B
I have not seen the Hotfix referred to as Hotfix 3?
The 2016 Feature Line Hotfix can be found here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
vinceroux
I'm sorry, I meant the feature line hotfix, not hotfix 3. Hotfix 3 exists but is unrelated.
https://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autodesk-C2...
The problem I have encountered applies to the grading objects attached to non-closed feature lines. The grading object breaks into static feature lines. Feature lines on their own are not affected (from what I can tell).
I'm running civil 3d 2016, service pack 2, all the updates/hotfixes.
vinceroux
I see hotfix 4 has been released, and no mention of this problem being fixed...
Am I missing HF 4 in the download list?
Jeff_M
bscott, it should appear in the Autodesk Desktop App. I saw it, downloaded it, installed...and was greeted with a message that my install is already up to date, no need for the HF. But, as far as I know, I have not ever applied this hotfix (it was released today), nor did I do any Beta testing for it. <shrug>
Jeff_M, also a frequent Swamper
vinceroux
Indeed, it appeared in the new autodesk desktop app. But like I said, didn't help the broken grading object bug that I described earlier in this thread.
