ROW from parcel tool is not generating. any solution?
i have created some properties from "parcel from object"
my alignment is passing through them.
i went step by step for ROW generation. but nothing is generating
Solved by samir_rezk. Go to Solution.
Hi @Anonymous
Please confirm that your Alignment and Parcels are both located in the same Civil 3D Site
Samir Rezk
Technical Support Specialist
Hi @Anonymous
After looking into the drawing, I noticed that your Alignment and Parcels are not in the same Civil 3D Site. Move the Alignment to the Site containing the Parcels and then you will be able to create a ROW because the two object will be in the same container there by able to dynamically interact together.
here is a link for some more info about Sites
Hope this helps,
Samir Rezk
