I need a routine to draw pivot spans automatically as shown in the following image. I tried looking on the internet but I couldn't find it, if you can help me create one or know of one that already exists I'd appreciate it.
I leave below the youtube link for a video demonstrating a similar routine.
https://www.youtube.com/watch?v=iESuFuirroU&ab_channel=MarcioCarvalho
Not 100% sure I know what a pivot span is but the image in my mind is asking for a dynamic block <array>
Joe Bouza
Pivô is an irrigation system widely used in Brazil.
My goal is to be able to draw it in autocad in an automated way.
I'm with @Joe-Bouza .
This looks like an opportunity to use a dynamic block.
Dynamic blocks are part of core AutoCAD.
The AutoCAD forum has a Dynamic Block subforum
I think you will have better luck there.
(You can repost or "Report" and ask the moderator to move the post.)
I also suggest that additional information be provided:
Is the number of segments variable?
Is the length of the segment variable?
Is the end segment a different length?
Do you need to accommodate a less than 360-degree layout?
a
Christopher Stevens
Hi Guilherme,
That irrigation system is also widely used here in the Western USA. There might be a manufacturer somewhere, either US or Brazil, with CAD drawings available for design. Dynamic Blocks look like a good way.
Dave
Dave Stoll
Las Vegas, Nevada
I watched your video. looks like a dyno block will do this.
post you primitives' and list your parameters
Joe Bouza
