Civil 3D Forum
Rotate Label - Align with Polyline
4 REPLIES 4
david.graham
146 Views, 4 Replies
Hope someone can help,
Is it possible to create an expression that will rotate the label so it is aligned with the polyline. in the Rotation properties in the Style Traits dialog box. (see image 2). The label comes from the object table and i have been able to get the label to position at the first X,Y,Z. (see image 1).
Ideally i would like the label to use the first and second Vertices for reference, this should allow the label to align perfectly along the line.
Label_Alignment.JPGLabel_Alignment_Properties.JPGI am trying to create an expression that
4 REPLIES 4
Pointdump
in reply to: david.graham
Hi David,
Have you tried Justification >> Bottom Center?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
david.graham
in reply to: Pointdump
Yes, unfortunately its not the justification that is the issue, the porblem is that the label is aligning to the Polyline, using the first and last vertices, where i need it to align using the first and second vertices
Pointdump
OK, I see now. You might want to also post this in the >>>Map 3D Forum<<<.
Dave
Dave Stoll
Las Vegas, Nevada
david.graham
Thanks, i will do this
Rail Community
