road ditch design
road ditch design
road ditch design
hello
I have to design a roadway with two ditches. on my insert I am only showing the right side as I will mirror once I have done one side. I can not get the assembly to follow my horizontal and vertical offsets. maybe the assembly I am using is not used for horizontal and vertical designs. I can not used the assembly because the ditch varies horizontal and vertically.(of course has to flow.) under target for the road corridor I have used and assigned my horizontal and vertical data into the corridor. I have used the right side only and have not mixed the left side.
please help
M_c3d
Can you share the dwg? It will be easier to see what the problem is
ok here it is. I have noted on dwg my uncertainties.
it would be great if I get some directions. thank you so much
it is civil3d 2018
sboon
Attachment missing?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
I attached the dwg
Dwg is not going thru
I have posted a dwg
