Hello Sirs,
Here is my problem. I have prepared a subassembly using subassembly composer for a project with all the targets, cut and fill daylight points and links as can be seen from the attached .pkt file. However, after importing the .pkt file (subassembly) into Civil 3D and modelled the corridor, the cut day light is not created properly. To further clarify the matter, the existing surface continues and overlays over the corridor surface (the cut daylight is not shown to cut through the existing surface) for stations of the road where there is a cut situation. This can be seen from the attached Civil 3D attached drawing. In addition, I have checked and made sure that target maps with the existing surface. Am using Civil 3D 2022 with Civil 3D Subassembly composer 2022. Could anyone please give me a solution?
Thank you in advance.
Solved by bonteng88. Go to Solution.
Hi @Abdissa34
In your Drawing there is only EG Surface, there is nothing wrong with your Corridor, it do have CutDaylights in it but it is positioned below the EG Surface. What you need to do is to make Road1 and Road6 Surfaces then a new FG Surface with definition>Edit>Paste Surface.. EG, Road6 and then Road1 in sequenced , Then Set NoDisplay to EG Surface as shown in Below Pic
attached is the drawing that has been edited
Thank you for taking your time to look for a solution and reply to the request. However, do you always have to create an FG surface everytime you create a corridor or has it only happened in my corridor file only? Could you please clarify. In addition, would the solution in your post affect section view creation and volume calculations?
Thank you, it works. I have checked the file you posted. Its great eye opener for me regarding combining surfaces in Civil 3d too.
